alternator connection
14 years 2 weeks before #27144 by manual-mecanica
alternator connection published by Manual-Mecanica
Hello friends, I have an 110 AMP Valeo alternator that I bought in a workshop I am adapting to a Toyota Corona what is not the symbology of the connections that bring SL fr.
14 years 2 weeks before #27170 by manual-mecanica
Manual-Mecanica response on the Re: alternator connection
The S is generally the battery and L is the pilot light depends on the year of your crown may or may not carry a voltage of ignition that would be marked Ig but if it is modern it carries a line of control to the Ecu but if the one you are going to put only has s and l only those you must connect.
