Honda chord does not turn on until after a while
14 years 2 weeks before #27112 by manual-mecanica
I have a Honda Chord 1990 my problem is that when I turn everything right for the first time, the problem is that when for example I already bring it a good time working and I stop saying in a store in what I enter and I go up to the car and I want to see it I do not turn on I have to wait for a minute or less to learn again, another is when I get to the gas station and turn off the engine in what they finish the gas. I start no longer turns on, I have to wait a minute for less and I give it and turn on ...
I would like to know the possible failures of this problem in advance thank you very much .....
14 years 2 weeks before #27119 by manual-mecanica
I need more data, after you stop and try to turn it on again, "the engine revolves, it does nothing, it turns heavier" if you tell me a little more perhaps you can help you.
14 years 2 weeks before #27121 by manual-mecanica
Hello, your problem can be in the RPM sensor (called the upper dead point sensor. Once you can have a small breakdown the winding of it. Or if you do not take it out and try to clean it, it wars, then comment as it went with that.
14 years 2 weeks before #27176 by manual-mecanica
If the car, if you go normal, be and will be but do not turn until after a minute and turn on normal ...
14 years 2 weeks before #27177 by manual-mecanica
I am going to check what you tell me to Cesar and then I tell you if the problem was solved ......
