Transmission landslides
17 years 8 months before #2707 by manual-mecanica
MANUMENT -MECHANICS PUPPLY
: UNSURE: Middle companions, I have a Spirit RT I am going to make the tuning of the box but I have a doubt, what is the procedure to adjust the bands of this transmission. There is someone to guide me ....
greetings.
17 years 7 months before #3061 by manual-mecanica
Manual-Mecanica Response on the Re: Slide in Transmission
Do not indicate if I was skating but if it is a normal tuning you have to remove the valve box and the adjustment screw, which is located below it should not give it more than one and a half and a half ok? The one on the outside is that of reverse also should not be very tense if it does not give reverse problems I recommend not adjust this, test adjust the overwhelgal boy
