Light K Orange XSara Coupé 167 hp 1999
14 years 2 months before #26955 by manual-mecanica
Orange K Light on 1999 Xsara Coupé 167 HP - Posted by manual-mecanica
Hello.
I have a 1999 Citroën Xsara Coupé petrol, 167 hp. For some time now, about 10 minutes after starting the engine, the orange "K" light comes on in the dashboard and the engine starts to misfire and barely accelerates. The next day, when I start it again, it starts perfectly, the engine runs perfectly, but after 10-12 minutes, the same light comes on and it starts misfiring, barely accelerating. What could be wrong? The engine has 150,000 kilometers, it's always been serviced at a Citroën dealership, and the catalytic converter and front lambda sensor were replaced a while ago. What could be the problem?
14 years 2 months before #27068 by manual-mecanica
Manual-mechanics ' response on the topic Re: Orange K light comes on Xsara Coupé 167 HP 1999
The first thing you should do is connect the diagnostic tool, but your problem seems to be in the high-voltage ignition coils, a common failure in this type of engine.
14 years 2 months before #27070 by manual-mecanica
Thank you so much!
If it turns out to be the coil... is the repair very expensive?
Thanks again and best regards.
14 years 2 months before #27084 by manual-mecanica
If it's not sparking, then I don't think it's the coil. I'm leaning more towards the temperature sensor or fuel pump. Anyway, if the light is on, it's best to get it scanned
14 years 2 months before #27127 by manual-mecanica
Thanks again. Yes, I'll take it to the dealership to have it scanned; I'm afraid they'll charge me for it... Anyway, what I find most strange is that everything is fine for the first 10 minutes. The car runs well, accelerates perfectly, and the orange K light doesn't come on. After 10-12 minutes, when the engine warms up, the problem starts. The light comes on, and the car starts to have much less power. Why does it happen after 10 minutes and not right after starting? That's what's puzzling me the most.
Thanks again, and best regards.
