ask
17 years 8 months before #2689 by manual-mecanica
Question posted by Manual-Mecanica
Hello greetings I have a question ami car passed
water to oil. What problems will be the engine and
wings that can happen to you thanks
17 years 8 months before #2698 by manual-mecanica
Manual-Mecanica Answer on the Re: Question
If water has happened to the motor oil, it is most likely because the butt joint is burned or the cracked cylinder head.
In the first place you have to repair that breakdown and once it is finished changing the engine oil and cleaning the engine cooling circuit well.
Rolling with water mixed with water can cause engine destruction since the hydrogen peroxide and lubricate the lubricating oil capacity.
All the best.
