Unstable idle
14 years 3 weeks before #26892 by manual-mecanica
Manual-Mecanica Response on the Restable Read
Servilimit wrote: Hello Cigsala.
Check the cable that carries the pedal signal to the accelerator arm, can be locked inside the case for some damage or dryness, I think it is only that. Luck.
Miguel.
Thanks Miguel for your time.
14 years 3 weeks before #26919 by manual-mecanica
Look that when you start a trigger to the pedal in the snowfall it is the same and when you hit a trimming, luck
