Urgent help with UNS S10 2005 2.4 gasoline
14 years 3 weeks before #26843 by manual-mecanica
Urgent help with UNS S10 2005 2.4 gasoline published by Manual-Mecanica
Hello friends, I have a problem with an S10 does not turn on, I have no current in the fuel pump or in the spark plugs I already tried all their relay and currents and they are already well check the crankshaft and cams
14 years 3 weeks before #26850 by manual-mecanica
Manual-Mecanica Response on the Re: urgent help with UNS S10 2005 2.4 Gasoline
Hello, look if the contact key is with transponder or chips could be
14 years 3 weeks before #26859 by manual-mecanica
Did you check if it carries a pill in the distributor?
14 years 3 weeks before #26868 by manual-mecanica
Czech that you do not lack connecting any earth cable in Chevrolet they bother quite a lot and there is no spark or injection.
14 years 3 weeks before #26895 by manual-mecanica
If the key has a chip already with the other original and nothing when giving it does not turn off the truck with the key and also the check Engine remains flashing and does not use a distributor is totally electronic and already check all the poles and they are fine
