Matiz 2007 very forced to roll ...
14 years 3 weeks before #26835 by manual-mecanica
Matiz 2007 very forced to roll ... published by Manual-Mecanica
I have the next problem with my 2007 nuance, 15 days ago I was given it after a problem with the key and others ...
The fact is that from the day I give it to me the mechanic I feel as if I always wear the brakes, I feel very forced to walk when it had always been a very practical and soft car when driving, the case is that I think it is from the front tires since I have to hold the steering wheel. To that side.
Could someone tell me whether it can be the balats or what can it be? Before taking it to the mechanic and getting money again.
14 years 3 weeks before #26847 by manual-mecanica
Manual-Mecanica Response on the Re: Matiz 2007 very forced when rolling ...
Hello iedwardp3.
From what you tell us it seems that the direction is misaligned, in that case you will run out of tire if you continue to shoot it in that state. You have to align the address before anything else. Luck.
Miguel
14 years 3 weeks before #26854 by manual-mecanica
It won't be the Valero that was mother and changed cousin ?????
I put it well easy to know if a tire is braking; Raise your car with the cat, the tire that is free to rotate with your hand, with strength if you turn freely, you have no problems, if you do not turn or are forced, you are right, it is slowed, so with all the wheels, shelter them well those that are left on the ground for you do not have any accident.
14 years 3 weeks before #26865 by manual-mecanica
The strange thing is that you took it by a problem with the key, nothing will have to do with the wheel or performed another repair in addition to the key, because as they say servilimit can be misaligned, but only and without a blow this half difficult, or as Pinida says that the Valero is evil, but the same is only complicated, Czech that roll front or in one of the wheels.
14 years 3 weeks before #26871 by manual-mecanica
Thanks for your answers I will do the lifting and turn tire on tire to see if any resistance.
The Valero who changed me before is a rear tire, and I just realized that my steering wheel is no longer aligned either and to make the car the car I always have to go slightly to the left, so I still believe that there is something in the front ...
but I check that and if not I take it to alignment and comment.
It takes me out of wave that everything was in the back and the key and now the problem is in the steering wheel (I begin to distrust my mechanic): Angry:
greetings.
