drowning when starting (solved)
14 years 3 weeks before - 13 years 10 months before #26814 by manual-mecanica
He drown when he started (solved) published by Manual-Mecanica
That such colleagues I have an Oldsmobile Cutlass Supreme
1996 that when it starts it drown and smells a lot of gasoline
has a new gasoline pump, new gasoline regulator,
new gasoline filter, I ask for your help oriente that it can
be, in advance I thank you, Salu2.:( :( :(
Latest edition: 13 years 10 months before by .
14 years 3 weeks before #26827 by manual-mecanica
Manual-Mecanica response on the Re: drowning when starting
The check is off?, well, the excess fuel at the start is almost always the fault of the refrigerant temperature sensor, but it can go through injectors that do not have a tone, or the oxygen sensor that directly affects the MESCLA, now the flow and the TP are also factors but these are more presented with the vehicle already torn off.
14 years 3 weeks before #26830 by manual-mecanica
I have the Cherokee that is in the photo, I have had two Grand Cherokee and I have applied the same in the three vehicles that the same thing happened to me, at the beginning I thought it was the oxygen sensor that also causes this type of failures, to get out of this doubt the oxygen sensor does not It produces this fault, another thing can be the catalyst if it has it, it must be calcined, and finally the silencer or escape bottle .. In my case it has been the silencer covered in one and another the oxygen sensor in short this for as if you had a car forward ...
14 years 3 weeks before #26860 by manual-mecanica
That kikemec comrade, notice that now that you mention
the check Engine, it is not turned off, it is on, a question
and forgive my ignorance that is the flow and the TP, the truth is new in this mechanics but
I really like this of the mechanics, Salu2.
14 years 3 weeks before #26861 by manual-mecanica
Thank you Cherokee 4x4, if you have the catalyst
I will try to take it off to see what happens and then I will
check the oxygen sensor, thanks for your help, Salu2.
