ask
17 years 8 months before #2679 by manual-mecanica
Question posted by Manual-Mecanica
Hello, good afternoon if someone can help me with it will be able to know what probability
there is that the antifreeze of my radiator c balla al escape. Greetings
Thank you
17 years 8 months before #2684 by manual-mecanica
Manual-Mecanica Answer on the Re: Question
Wait for us to look at the glass ball ball to guess the car you have, the engine that carries and its future.: Laugh:
17 years 8 months before #2688 by manual-mecanica
Hello, Barriwai, a plaser, if there can be your question, you can have a joint plate
17 years 8 months before #2699 by manual-mecanica
I think the same as Maat, it looks like a cylinder head or a butt joint, the water does not disappear because yes, if there is no leak or a trace of dry antifreeze, it is possible that it is being put into the cylinders through the Board of Board. (You have also published another post with a very frequent problem when the Board of Cuhata is burned)
Greetings.
