Racer 1.5 '94
14 years 3 weeks before #26787 by manual-mecanica
Racer 1.5 '94 Published by Manual-Mecanica
Good afternoon friends of the forum ..... I tell you I have a Daewoo Racer 1.5 year 94 I changed some seals and hoses because I bounced water after this I went to walk and I did not start anymore ..... I check it and I did not throw me spark .... I change the ignition module and py nothing I check if it sends a signal and the signal is ok. I don't throw spark .....
thank you very much .....
14 years 3 weeks before #26820 by manual-mecanica
Manual-Mecanica Response on the Re: Racer 1.5 '94
You checked the crankshaft position sensor? You connected all the lands? And Czech if you connected all the connectors you took to change the cells.
14 years 3 weeks before #26829 by manual-mecanica
It was everything ... Ok check the sensors and everything ok. The problem was the ignition module that they bought failed salt I got another with a friend and part to the first one ..... a council for everyone not to trust. In the new spare parts they can be damaged or bad ...
