Putting (synchronization) Daewo I hope 1.5cc
14 years 3 weeks before #26753 by manual-mecanica
Hello, I need to know how I get ready (synchronization) Daewo I hope 1.5cc Multivalvular ... If someone can happen to me as it is done, I would appreciate it
14 years 3 weeks before #26759 by manual-mecanica
Hello friend, you have to do it in the ancient way
1. take out a spark plug of the first cylinder and you see that the piston is above
2. take out the valve lid and place the camshaft in balancing the valves of the cylinder 4
14 years 3 weeks before - 14 years 3 weeks before #26777 by manual-mecanica
Hello thank you for your advice ... but by chance you do not have the manual, since many times there is comes out with schemes, photos, etc. Where each gear is going and points ..... Talk to the mechanic and tell me that I try to put it to do but it does not find it ... it tells me that it reminds you that it is multivalvular
Latest edition: 14 years 3 weeks earlier by .
14 years 3 weeks before #26780 by manual-mecanica
Even if it is multi valvular, the motor cycle is the same search on the webb and magister.com page to see if the manual of this lucky vehicle is
14 years 3 weeks before - 14 years 3 weeks before #26782 by manual-mecanica
Thank you for your help in Emagister, they helped me here I sent the file in case it serves someone. Oh tells me that I can't upload it ... but if someone needs it with pleasure, I will send it to him ... even if he insists on raising it
