Increase nuance power!
14 years 1 month before #26640 by manual-mecanica
Increase nuance power! Posted by manual-mecanica
Good, this time I write to listen to opinions and tips to increase power or improve the performance of the engine of a nuance!
Any suggestion is accepted!
14 years 1 month before #26646 by manual-mecanica
Manual-Mecanica response on the Re: Increase nuance power!
It depends on the results you are looking for, if what you want is to increase power, start with a forested induction, injectors, multiple exhaust changing, or directly chipeas the ECU, if you want to improve the economy later eaten by a basic tuning.
14 years 1 month before #26650 by manual-mecanica
Mm ok, another query, I know that it sounds ilogical, but that can help so much if a fancoler is placed in the conical filter pipe and the acceleration body? I have it alone with an adapter, without pipe .. that is the filter the adapter and direct to the acceleration body
14 years 1 month before #26658 by manual-mecanica
I have not had much experience with the Fancoleer, in terms of doing the installation and providing some change, but of those that I know, they say that it hinders the passage of air is time to increase the flow, with the direct induction vast, according to the colleagues who have given me their opinion
