DMAX TRUCK 2006 3.0
13 years 10 months before #26573 by manual-mecanica
DMAX 2006 3.0 Truck Published by Manual-Mecanica
Estimated I hope someone can help me, I have a DMAX 3.0 truck from 2006, and this one that goes out to me.
13 years 10 months before #26575 by manual-mecanica
Manual-Mecanica Response on the Re: Dmax 2006 3.0 Truck
The first thing is to know with what kind of equipment you are diagnosing and what are you accessing, because that fault code applies for ABS chassis systems, stability, suspension etc., there could be a loss of communication with the ECM and the EBCM encodes it in this way, however it is a hypothesis that you must check with a equipment of diagnosis of the OEM level, because with generic equipment this usually happens. False fault that prevent a good diagnosis
