Well, I throw you high, it means that there
you have to check that the gasoline pump will throw the precion corresponding, with a fuel manometro.
If that gives the pump problem
(I think it has to give 3 bar when you give it contact and 6 to 8 when you start and turn it off and you would be the valve, it has to stay there for about 20 min cannot go down from 6 bars, I think, to make it more generally, you can not lose more than 1.5 bar)
good discarding that, the following is the check of rotation sensors, both as a rpm of cranks or if you have a rp.
If all that does well, I wake up to go for oxygen and etc.
Once you download any sensor problem you already have to see if the wiring has signal losses
if you can connect the car to a serious scanner, it will tell you where it has the failure and start looking for there
I hope to break you in some help
