Transmission E4od year 1995 does not go a march
13 years 10 months before #26558 by manual-mecanica
:( Good to all, I have the problem with this box at: e4od -ford, Econoline 3,500 - year 1995.
Well the problem is that the car is not going, we check the part of the discs, clutch, and others, this is all good has burned albums, medium the pressure of the converting par, and it is fine, check the current that reaches the selenoid body and also comes current, in this model it carries 5 selenoids, the truth does not know more to check it to find the problem, if someone can help me with my problem, I would like to give it a problem. ,thank you so much:)
