Ford Ranger 1996
13 years 10 months before #26519 by manual-mecanica
Ford Ranger 1996 published by Manual-Mecanica
Hi, I have a Ford Ranger 96 3.0 Naftero truck, and I have a consultation, when I press the clutch to put my revolutions for more than I have it in neutral when putting it instead it is normalized, they can help me with this problem
13 years 10 months before #26521 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Ranger 1996
Your problem is the valve that controls the
slowdown has 2 pernitos head 8mm saclala,
then clean it with a spray to dissolve
dirt and finally
the lubricas, all for the 2 subsequent holes it possesses.
Atte. Diver18
13 years 10 months before #26525 by manual-mecanica
Hi diver18 thanks for the fast answer, but you can tell me what part is that piece.
13 years 10 months before #26526 by manual-mecanica
It is located at the top of the engine (admission collector)
next to where the thick hose of the air filter arrives. The piece is cylindrical and at the tip it is under the plug is totally winged.
Atte Buzo18
13 years 10 months before #26532 by manual-mecanica
Hello, the valve is called step by step fix that in the back of the tab has a white plug behind it has a record but carefully because it is simple it is regulated with a fuse screwdriver if you take it out clean with some solvent and slightly lubricate it.
I hope I helped you a hug
