Escort problems
13 years 10 months before #26486 by manual-mecanica
Escort problems posted by Manual-Mecanica
Well, it fails as if a valve was flamed, but already check the compression, the pressure of the pump, which is what I will have, take out the spark plugs and were wet with gasoline, mmm what could it be? It is an American 97 escort, I wait for your responses !!
13 years 10 months before #26490 by manual-mecanica
Manual-Mecanica Answer on the Re: problems of an escort
What is a flamed valve ?? And what is the fault it presents ... Did you already check the injectors .. ??
13 years 10 months before #26492 by manual-mecanica
Look, a flamed valve we tell you when the valve (whether escape or admission) does not seal well with the engine's head, and I also thought about the injectors but already check them and they are fine, the fault k does it is K does not have a minimum march, and when you accelerate it, I am going to check the MAP, the pressure regulator, and the sensors of oxygen You have another opinion I would like to listen to it !!
13 years 10 months before #26494 by manual-mecanica
Have you already scared it?
13 years 10 months before #26495 by manual-mecanica
already!! But it doesn't give me anything concrete !! How Kiera I'm going to Check it
