Ford Edge does not start
14 years 1 month before #26474 by manual-mecanica
Ford Edge does not start published by Manual-Mecanica
Friends someone could help me. I have a 2008 Ford Edge
Motor 3.5L. We change the instrument board and now it does not start.
14 years 1 month before #26475 by manual-mecanica
Manual-Mecanica response on the Re: Ford Edge does not start
Regularly in this type of vehicle, the board is a D command unit, that is, a computer that can be twinned or shared a configuration with the alarm immobilizer computer, with the engine computer and with other possible units D control. And that configuration is only pointed to introduce it with the original scanner or a similar one so that the vehicle remembers the new board and can allow it to turn on.
14 years 1 month before #26476 by manual-mecanica
Thanks for the answer. To configure the board, the old board is needed?
14 years 1 month before #26482 by manual-mecanica
Not necessarily but you can put it to make sure it garment. The truth is that I recommend so that you will take it to an agency so that they say whether or not they can be scheduled
