Renault 11 starter engine
14 years 1 month before #26438 by manual-mecanica
Renault 11 starter engine published by Manual-Mecanica
I tell you to see if someone can help me, when I give contact to the car to start the automatic noise but the car's current is cut, I have to disconnect the battery to have the current again but when trying to start the engine the same problem, the automatic andubo changed for a time but returned the problem that can be, the fuses are all good. Thank you already
14 years 1 month before #26449 by manual-mecanica
Manual-Mecanica Response on the renault boot engine 11
Hi Renault ????:lol: Check ... when you say that the current is going to the car ... do you mean that the ignition is cut? Let's say, do the dashboard lights go out? And the sound that the automatic makes you .... it makes a tac-trac-
trac
It seems contacaco fault of one of the lines.
14 years 1 month before #26453 by manual-mecanica
Completely agree with WTO, it sounds like a contact failure or that the battery is very low and not endurance, but if you disconnect and connect and part well then there are not many opsions that is to say that it is a problem of starting itself.
