Help with cash noise of a nuance !!
14 years 1 month before #26402 by manual-mecanica
Help with cash noise of a nuance !! Posted by manual-mecanica
Good, I have a problem that when I turn on the car, you have a noise like a pounding, and when the clutch lever (croche) is flooring, it takes off, but if I release it,
it would be an oil problem in the box? And as I would do since the car is synchronous.
Thank you!!
14 years 1 month before #26403 by manual-mecanica
Manual-Mecanica response on the Re: Help with cash noise of a nuance !!
That is Croche Collarin
14 years 1 month before #26405 by manual-mecanica
Is reparation expensive? or how complicated it is to do so?
14 years 1 month before #26414 by manual-mecanica
It is not so expensive, doing so even being a mechanic is complicated, many tools and a lot of, but a lot of passance and pressure.
