Cla CL CAL IN RENAULT KANGOO 15 DCI OF 203
14 years 1 month before #26396 by manual-mecanica
CL CL CAL CAL IN RENAULT KANGOO 15 DCI OF 203 PUBLISHED BY MANUAL-MECANICA
Hello friends, I have a problem with this Renaul Kangoo 15 dci car, the problem is that when the march with the car is heard a cla cla, and the direction labeling and the bearings that go on top of the shock absorber, and a transmission twice because I thought I could come defective, but still sound that noise the cla cla, I have lacked to change the other transmission but that noise comes from that noise. Changed the transmission, someone had something similar?
14 years 1 month before #26416 by manual-mecanica
Manual-Mecanica Response on the Re: Cla Cla Cal in Renault Kangoo 15 DCI of 203
You should be a bit more specific, is it when moving it?, when starting? is it always? Sounds when double or straight?
14 years 1 month before #26421 by manual-mecanica
I tell you that once, in a Renault Megane, the semi -triceta (velocity box) was broken and the noise felt on the wheel, that is, at the opposite end, as if it were the broken homokinetic or the wheel bearing. Cordial greetings.
14 years 1 month before #26425 by manual-mecanica
The first thing you have to check are homocinetic, but I would have to make noise also when folded in a corner. If it is the semi -triceta that goes to the box I would have to vibrate in speed in addition to the noise when it tractions.
Ruleman unlikely, I would have to have the wheel to make that noise. Lift the wheel and take the game grabbing from above and down.
14 years 1 month before #26507 by manual-mecanica
Hello, because the noise begins to do it from 40k/Hy it is shown on the right side, on this side it is the one that has changed the transmission 2 times
