gasoline pressure
14 years 1 month before #26216 by manual-mecanica
gasoline pressure published by Manual-Mecanica
good friends .. I have an urgent help I have a problem with my eclipse 1992 Comor 2.0 4G63 .. I started as a lack of fuel .. When placing the new pump the car charred me the spark plugs in minutes .. and with a fault D until explosions .. medium compression and everything is bn .. dcidi buy an adjustable gasoline regulator .. and graduate at 40 lbs and m. Will it be the Normal Working Pressure of my car? since I can't find this problem in the XQ D .. thanks to hand in hand
14 years 1 month before #26219 by manual-mecanica
Manual-Mecanica Response on the Re: Gasoline Pressure
B) Rev The entire ignition part spark plugs, cables, and fuel feeding filter and injectors can suddenly be a failure in the injection rail
