My Opel Astra does not start after changing alternate
14 years 1 month before #26194 by manual-mecanica
Hello everyone, after changing the alternator, and the battery although new, it was downloaded and has been used at least 5 months, they left me a portable device that they call starter, connect it to the terminals of the battery, the box on and made the attempt to start but I did not start.
My question is, do I need to put a full charge to the battery?
14 years 1 month before #26205 by manual-mecanica
Manual-Mecanica Answer on the Retra Opel
Hi, you would have to prompt with a well charged battery to get out of doubt and rule out that it was the battery .. greetings you will tell me
14 years 1 month before #26252 by manual-mecanica
Hello partner according to accounts you have had the battery put to the car for five months without using. As long
14 years 1 month before #26261 by manual-mecanica
Please companion where the brooms of the start -up are. How do you see I am a firecracker.
Thank you.
14 years 1 month before #26263 by manual-mecanica
You can hit him (with a little tention to not load anything.) To the starter engine so that they sulate the brushes, but I doubt that they are stuck, most likely the battery is vague, you should try another. Salu2
