compression
13 years 9 months before #26175 by manual-mecanica
Compression Published by Manual-Mecanica
good I just acquire a compression meter .. I would like to know what steps to do a correct measurement .. and if they know what should be the compression of an eclipse 92 4G63 2.0 engine thanks
13 years 8 months before #26247 by manual-mecanica
Manual-Mecanica Response on the Re: Compression
Hello, you will see the realption is
1: 9.0 this is the right greetings
13 years 8 months before #26265 by manual-mecanica
Disconnect the ignition, remove a spark plug or injury, and by the hole put the compresimeter and drive the start until I read you. I hope I have helped you.
13 years 8 months before #26266 by manual-mecanica
I forget, I will make you the compression reading of each cylinder, one by one.
13 years 8 months before #26276 by manual-mecanica
9.6 bar with the accelerator to the maximum and with the indications of Eldevictrus Luck!
