Missing Ford Ranger 2.3 1995
14 years 1 month before #26167 by manual-mecanica
Missing Ford Ranger 2.3 1995 Published by Manual-Mecanica
I have Ford Ranger 2.3 1995 does not consume oil and does not smoke Air and benzine filter new oxygen sensors and lip siege Air and injection system Spark plugs and new cables is changed clutch kit ... but does it have no power? Help thanks
14 years 1 month before #26173 by manual-mecanica
Manual-Mecanica Response on the subject Re: Ford Ranger Power 2.3 1995
Friend ravisa the brands of the distribution. and the other sticks a clean to the flow.
14 years 1 month before #26174 by manual-mecanica
Czech suggestion the maf sensor ........ and also gasoline pressure ....... Good luck
14 years 1 month before #26176 by manual-mecanica
After all that look at the escape if it is not covered, you want to have a lot of resistance to the exhaust gases, a greeting
