Astra 1.8 reheating
14 years 1 month before #26060 by manual-mecanica
Astra 1.8 Reheating Published by Manual-Mecanica
Good night friends, I write to you because I have a problem with my astra 1.8 and I have not been able to solve it.
The problem is as follows, for months my astra overheats the early one passes more than 95, and when I turn on the air conditioning it reaches red and I have to turn off the car, I started by changing the thermostat along with the temperature valve, I purged several times with refrigerant and follow the problem, I finally realize that the electro -seasons are uncontrolled, when I turn on the car in the morning (first ignition) They light at their maximum speed, then slow down and the problem begins ... I don't know what can be? It seems to me that it is a problem with the electros, they turn on but they go out and then turn on again and in that cycle they are! Can someone help me ?? Thank you very much in advance.
14 years 1 month before #26376 by manual-mecanica
Manual-Mecanica Response on the Restra 1.8 Reheating
Hello, how are I had a similar problem with a car of those Mira checks the modulus of reliefers of the electro -seasons.
luck....
14 years 1 month before #26380 by manual-mecanica
First Czech the state of oil and water so you are almost certain that it is not a butt joint,
14 years 1 month before #26445 by manual-mecanica
Hi Jose, thanks for your answer ... tomorrow I put on that .. because that problem really has me on the edge of madness and haha, in my country they discontinued those cars and it is difficult to find spare parts and much less a mechanic that fixed it, yesterday I started putting some rely that they lacked and the thing was worse, the tacometer needle when it passes from 50 does not go to 0 Well, in case the water is not consumed almost, it is in its maximum value ... almost that every middle month I replenish it, thanks for your responses.
14 years 1 month before #26456 by manual-mecanica
Venezuelan It is not normal for the vehicle to start in the morning, the electros are listed, they have to enter once the heating cycle has been carried out, and it is not normal that the temperature sharply rises, here it usually begins with the easiest check of radiator and temperature bulb and obey the thermostat, but it is to have an eye with the water pumps in these models are quite annoying.
