ALTERNATOR PULLEY RENAULT MEGAN II 1.5 DCI.
13 years 9 months before #26006 by manual-mecanica
Someone can tell me please, if the alternator's pulley is normal for olgure from front to back, or it carries a cluting system. I would appreciate them very much to give me information, a cordial greeting for everyone, thank you very much
13 years 9 months before #26007 by manual-mecanica
Manual-Mecanica Response on the Re: Alternator Renault Megane II 1.5 DCI.
My megane does not have it. In fact, I had a problem with that slack that the service belt when wearing, put a piece in the distribution making it jump a tooth, by the clearance on the pulley. Anyway Renault correct that problem and the best that pulley goes like this.
13 years 8 months before #26984 by manual-mecanica
Alternators' pulleys have a kind of clutch (in the direction of the clock it drags the axis and on the contrary turns alone. If this bad is not a common failure.
13 years 8 months before #27016 by manual-mecanica
There is no olgure in the alternators the pulleys are fixed, if you have a game, the bearing or inner bushings may be wrong, at least I have never seen an alternator with olgura I do not say that they do not exist but I do not think it is normal, since it discourages the belt and can mount.
13 years 8 months before #27065 by manual-mecanica
These alteners bring fixed pulley or free pulley depending on the year of the car. If it is free pulley, it makes the function of a bicycle pinion, just lock for the right. With this system the vibrations of the accessory strap are avoided.
