armed
14 years 1 month before #25914 by manual-mecanica
armed published by Manual-Mecanica
Hello friends, I am assembling a goal 87 Nafta to Carburetor I wanted to know if when placing the connecting rod in the piston you have position or can go anyway thanks.
14 years 1 month before #25951 by manual-mecanica
Manual-Mecanica response on the re: armed
If you have a position and the piston also breaks with a mark that goes to the front of the engine. The old mechanics have told me that the guide of the caps goes where the oil filter is. I do not know how true this will be but it is best to mark whenever one disarms something to be sure of what is being done. I hope someone else has another answer because that is what they have told me.
14 years 1 month before #25981 by manual-mecanica
Thank you very much for your collaboration
14 years 1 month before #25986 by manual-mecanica
The number goes to the escape side
14 years 1 month before #25989 by manual-mecanica
Hi CMMY_7 Look if you do not get the piston and you have the same views in the river of the piston is marked the side that goes, this marks is inressa or marked on the edge of the piston this brand is pointing out the distribution band and as the friendly friend says the numbers that are marked in the Vielas Dan Hasia the escape. greetings
