I need the ignition order
14 years 1 month before #25874 by manual-mecanica
I need the ignition order published by Manual-Mecanica
I need the ignition order or the order of time of a Nissan Pick Up 2006 with the 2.4 16 V engine
14 years 1 month before #25876 by manual-mecanica
Manual-Mecanica Response on the Re: I need the ignition order
Hello, how are you, look, I don't know, but I don't know if it helps you check it in Champion, you come in the catalog, you can download it from here:
I hope it has been helpful. luck
14 years 1 month before #25909 by manual-mecanica
Hello, in most 4-cylinder engines the ignition order is: 1-3-4-2
14 years 1 month before #25953 by manual-mecanica
When the order of ignition of an engine is not known, the easiest thing is to remove all the spark plugs put a wet paper plug in cylinder 1 to know when it is in compression at that time the engine compression will take the cap, then you put caps in the other cylinders and tours the engine in the direction in which it rotates and the order will be given to you the sequence in which the plugs are fired.
