Hello, hopefully someone has the knowledge and willingness to help me
I have a Mazda Allegro HB 1600 Model 1996 I have 2 problems (presented at different times) with rumato and the mechanics have only done to get money without result.
1. For 2 years. For times and especially on warm days, the revolutions begin to go down and upload, almost until it goes out first and then until it goes out at intervals of 3 seconds approx. I have to upload the passage of gasoline with the screw so that it does not go out because if I release the accelerator in a curve or a stop I remain without direction and without brake. No mechanic has found the problem.
2. After a change of retainers and packaging, a failure came out at low revolutions; that is to say while accelerating or in the lower part of each change, after when instead corcovea and in general it does not run out as before. He was changed to everything, spark plugs, high installation, valves were calibrated and nothing, just an Arctic after getting out of the workshop.
Bot a little smoke while it is cold but compression is not low, however it tends to reheat uploading and I have to manually turn on the second fan.
I really like the cut of the car and I hope someone helps me to rescue him. My thank you in advance.
