CHEVROTEL IMPALA 69
14 years 1 month before #25775 by manual-mecanica
CHEVROTEL IMPALA 69 Published by Manual-Mecanica
Friends I need a help Kn my self -absolute ... I tell you uncommon to repair this car since it was from my grandfather but it has been fed up without working ... I eat cleaning it bn testing part x part and in theory everything is fine ... the electrical system and that of gasoline all impeke. But by giving contact I can't make K Parta, well he only did it once but I can't disappoint K he has ... if they can give me some ideas, I would appreciate them
14 years 1 month before #25796 by manual-mecanica
Manual-Mecanica Response on the Re: Chevropotel Impala 69
Of course, if you have a lot of time stopped, it changes spark plugs and the fuel that is in the pond, clean with a sandpaper the coals of the distributor lid and check that the carburetor is not stuck, you have to check if you have a spark in the cables if there are, then bent benchmark by the carburetor and give it the game if the pump is evil or the level of the carburetor but the level of the carburetor is.
14 years 1 month before #25804 by manual-mecanica
Look I have a new battery and spark plugs ... the starting engine was to disassemble the brushes and that was the 1st fault. The Estanke was empty like that I only have benzina, after that I started 2 times but only x a couple of seconds and then stopped. The contact only gives me when he wants, generally the amperimeter gives me -. So I have made a direct bridge to the starter engine but how do you want and do not want D:
14 years 1 month before #25833 by manual-mecanica
But you tried the start outside before installing it?, do you want to need to be oxidized or dirty half, you have a test, put a test lamp and check the battery current that reaches the start, then check the sheet of the sheet that reaches the same start and final or not.
