VW distributor problem
14 years 1 month before #25721 by manual-mecanica
VW distributor problem published by Manual-Mecanica
Hello everyone, I hope someone can help me, I tell you that I have a 91 carbon electronic ignition. The car is well for everything that happens is that when it passes a faster than normal or falling into a bump or by some damage of the street "that in Mexico does not pass" haha ​​the car goes out and throw exploits for the escape then I have to get off the car and check the distributor and notice the distributor and notice that the distributor Safa and turns only then I accommodate the distributor's lid and pulls again I hope someone can help me since it is very incomed to be getting off the car in the suede thanks to hand thanks I wait for your answers
14 years 1 month before #25731 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with VW distributor
Amigaso, the ideal would be to change the distributor but a lot of silver leaves hahaha you can check that the rotor is not spoiled inside and that is why you turn to you, and if it is not therefore drill a hole once the rotor was put in position and you crusate an easy and simple pin, the other is to hit the rotor but it is wild farther hahahahas luck and let us know.
14 years 1 month before #25734 by manual-mecanica
I think that you check 3 things, the first is that you revive the spring of the central carbon of the distributor's lid, the second that you revive the spring that carries between the distributor and the tree that makes it spin and third Czech the lainas that go between this tree and the monoblock, it takes two at least, it may be that they have broken and that it is wearing a mel aluminum of the monkey of the mono distributor is greater, therefore it is safa when falling into a bump or jumping a bump
14 years 1 month before #25735 by manual-mecanica
The VW distributor is screwed to the engine for a kind of scorch that has a screw that we loosen with a 10 mm dic Rotor, if this does not work it is likely that the distributor is sweeping and you have to change it.
luck.
14 years 1 month before #25740 by manual-mecanica
Thank you very much for your answers that I did not answer them before but I was working but tomorrow I checked and warned them
