NISSAN CRINICAR START
13 years 11 months before #25532 by manual-mecanica
NISSAN CRAMPART PUBLISHED BY MANUAL-MECANICA
I detail the breakdown, in cold to the first but hot when giving the key you hear a click and I have to give it several times until it goes, this makes it more and more.
All the best
13 years 11 months before #25538 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan Primstar Start
Hello friend, you have not given the starting engine service for a long time? It seems to me that there comes the thing, check it, greetings. :)
13 years 11 months before #25546 by manual-mecanica
Thanks for the comment anyway when yesterday the boot indicated the chivato of heater and the engine did not go well as if it were three cylinders had never happened to me.
13 years 11 months before #25569 by manual-mecanica
Hello, you will see the theme of the heater indicative does not have to be heating this failure also executes it through heating is the failure of a valve of opening depression of the turbo and of engine depression systems is typical in premium
13 years 11 months before #25571 by manual-mecanica
I thank you for all the answers.
Today I have taken it by crane to the Nissan concessionaire they have connected the machine tell me that I gave them a failure in a cylinder that does not vat tell me with ?? It can be from the injector - the cylinder -u another bullshit, they will already call me to comment.
I have left there with that impression these are going to get the rooms, I will call you and I will tell you about the depression valve I imagine that it will not be a face because the injury supposes me that theirs will come out, add that I have also told me to change the starter engine.
Thank you
