CODE T/F MODE SW 2 33 (MITSUBISHI MONTERO 2001)
14 years 1 month before #25509 by manual-mecanica
I have a reading of the MMC Mutii Scanner of the MMC (SS4)
I need the reference of the fault, since I check all the cash sensors and control module and the same failure continues to appear, and the box is permanently put in 4x4.
What does the Mode SW 2 code 33 mean?
Thank you very much,
Roberto.
14 years 1 month before #25510 by manual-mecanica
If you have a 4x4 mode switch, it can be that this is giving you internally you have some resistance in the diagrams it says how much these resistances are so it is in Ford you could start with there
12 years 1 month before #43213 by manual-mecanica
Manual-Mecanica Response on the topic Code T/F Mode Sw 2 33 (Mitsubishi Montero 2001)
Hello,
I have the same fault code
but the problem is that it flashes the central orange focus but the 4x4 does not work only in 2h
I have reviewed the electric, pneumatic part, and follow the same, it seems that the problem is in the control unit of the transfer located in the central part of the board, I am checking it and if I have a positive response, I know it.
