Caravan 2.6 ´98 ignition problem
14 years 2 months before #25498 by manual-mecanica
Caravan 2.6 ´98 ignition problem published by Manual-Mecanica
Hello, I need your help urgently. When I want to turn on the car, it does not ... Start but it doesn't turn on. He stopped working overnight, although before this, when he turned on, he made a strange noise, like a click ... Then, he was driving and the engine went out, I could never turn it on. It was seen by an electrician, reviewed all the cables, connected it to the computer, but no fault came out. They told us that it could be the emulator (it works at gas or gasoline). I don't know if it will have to do, but in February we changed the gasoline pump, since it stopped working. I would appreciate them to give me a hand. THANK YOU!!
14 years 1 month before #25602 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition problem of caravan 2.6 ´98
It can be your immobilizer, Czech with someone in alarms, or open your suicht without going to leave it for 20 minutes later close it and try again, it works in Chebrolet in Ford and others may work luck.
14 years 1 month before #25605 by manual-mecanica
Something similar happened to me and after almost two weeks of review that was my crankshaft position sensor, it is like a small pencil and goes to the side of the Damper, replace it and lightning it on, I have a caravan engine 3.0 Model 96, I hope I help you the comment, greetings, greetings
14 years 1 month before #25631 by manual-mecanica
Thank you very much. Apparently it is the immobilizer. An engineer is solving the problem, he told us that he had to restart the computer. Thank you very much again. Your comments have been very useful. See you later!!
