Toyota 4Runner Motor 1kz problem
14 years 1 month before #25419 by manual-mecanica
Toyota 4Runner Motor 1kz problem posted by Manual-Mecanica
Good morning.
I wanted to know if any of you could help me I have a problem with a 4runner MTORO 1KZ we just changed it to the butt and it turns very well work well for 3 minutes past 3 minutes begins to throw a lot of smoke and feels a great smell of diesel and if it goes out for a while and then it comes to turn on it does the miso work well at the beginning and after 3 min he returns. To review and work very well I don't know if someone has happened to something similar and has an ide of what could be.
thank you
14 years 1 month before #25436 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Toyota 4Runner 1kz Motor
What color is smoke ???
14 years 1 month before #25453 by manual-mecanica
It is true color is important to determine the problem, although I imagine it is black, the clock of the temperature to have both data and tell us.
14 years 1 month before #25484 by manual-mecanica
The gray smoke,
already solved the problem, what I had is that when buying the new butt, it was sent to a rectified workshop to calibrate and settle the valves but made a bad settlement of the valves what I did is that the start and maintain it as 1 hour started and little by little it was removed the problem and in the end when the valves settled.
Thanks for your answers
12 years 8 months before #40218 by manual-mecanica
Manual-Mecanica Answer on the problem with Toyota 4Runner 1kz Motor
Hello everyone I have a problem with my Toyota 1kz suddenly a light similar to the orange turbo was caught ... well what ise was to look for some empty handles if they were broken or resacted and nothing ... The truck does not stop stretching is not patuda is well but it does not stop turning on that light I wanted to know if someone had that preblem or some solve xq I do not find the preblema thank you!
