Motor problems
14 years 2 months before #25373 by manual-mecanica
Motor problems published by Manual-Mecanica
Good how are a question the engine of my car tranco la vrala and the python the number four and the partion did not have lubrication the other three if they were lubricating I do not think it was the pump x that all had lubrication except that some way of knowing if the oil pump is bad I thank you for the help my car is a Ford Fiesta 2002
14 years 2 months before #25377 by manual-mecanica
Manual-Mecanica Response on the Re: Motor Problems
Good morning Felix.
The fact is that the engine already needs a greater repair, I do not know that the crankshaft and the cylinders have been affected, if they require change or remain with the rectified, in any of the cases you must change the oil pump since you are making an adjustment of your engine.
14 years 2 months before #25380 by manual-mecanica
When it is the pump failure you have more symptoms the light on the board and more components are damaged, the taquies sound, what must have happened is that a metal is revolved, so I think without seeing anything, if the lava comes out sanito is not a problem of the pump.
14 years 2 months before #25393 by manual-mecanica
Friend if the car sounded but they tell me that it was the chain I did not know and washed it was bent when it disarmed it, the Sigual already sent it to rectify myself at 010 the car sounded like it was gasoy and the light marked but marked since I had the engine a year ago and I pee that I was damaged but but if it were the pump I have me
14 years 2 months before #25395 by manual-mecanica
Metals turn when there is no lubrication and not because yes. A lack of oil, engine overheating, past of revolutions or sucking (pump) obstructed, lazy or loose, can cause a connecting rod to be founded, it is always one that melts and not all. B)
