I have a Peugeot XRD 2003, starting problems
14 years 2 months before #25215 by manual-mecanica
I have a Peugeot XRD 2003, starter problems published by Manual-Mecanica
The problems occur randomly, after walking a time of march, when you stop one hour, the engine should be made 3 start -up attempts, as it turns and does not respond. In cold, there is no problem, moreover, the night vehicle is outside a half shade, and in these raw winter mornings, I repeat, starts in the first attempt. Air problems has been verified and solved and solved in the fuel, control of heaters, in the end, the controls that one can perform.
14 years 2 months before #25220 by manual-mecanica
Hello I hope this helps you in Halgo, it is likely that the Igueñal rotation sensor is loose as well as its connector normally with the cold they contract and make contact and it is there that you have no problems
14 years 2 months before #25260 by manual-mecanica
Warmielec: Thank you very much for your attention,
I will verify it shortly and tell you.
14 years 2 months before #25270 by manual-mecanica
I spend that problem with a Peugeot and the big problem, eye in my case, it was the start, I didn't turn so many laps
14 years 2 months before #25279 by manual-mecanica
Kikemec, OK, yesterday I repaired the starting donkey, so we will see.
Thank you so much
