I have a Peugeot XRD 2003, starting problems
14 years 3 months before #25215 by manual-mecanica
The problems occur randomly. After driving for a while, when the engine is stopped after about an hour, it takes three attempts to start it, as it turns over but doesn't respond. When cold, there are no problems whatsoever. In fact, the vehicle is left outside overnight in the shade, and on these harsh winter mornings, I repeat, it starts on the first try. We have checked and resolved issues with air in the fuel, the heater cores, and all the other checks one can perform.
14 years 3 months before #25220 by manual-mecanica
Manual-mechanics ' response on the topic Re: I have a 2003 Peugeot XRD, STARTING PROBLEMS
Hi, I hope this helps you in some way. It's likely that the crankshaft position sensor is loose, as is its connector. Normally, with the cold, they contract and make contact, and that's why you're not having problems
14 years 3 months before #25260 by manual-mecanica
Warmielec: Thank you very much for your attention,
I will check it as soon as possible and let you know.
14 years 3 months before #25270 by manual-mecanica
I had that problem with a Peugeot, and the big problem, mind you, in my case, was the starter; it wouldn't turn over enough
14 years 3 months before #25279 by manual-mecanica
kikemec, OK, I completely rebuilt the starter motor yesterday, so we'll see.
Thank you very much
