Renaul Megane Expression, board emits noise moles
14 years 4 months before #25069 by manual-mecanica
Hello everyone, I'm new to this site and I've read some of the discussions, which I find very helpful. I have a Renault Megane II Expression, which makes a rattling noise, as if the entire front panel of the car is loose, every time I drive over a bump. I'd like to find the workshop manual so I can better visualize how to remove the panel.
Thank you in advance for your comments.
14 years 4 months before #25118 by manual-mecanica
Manual-mechanics response on the topic Re: Renault Megane Expression, dashboard emits noise
Friend, the workshop manual doesn't show the parts diagram for the dashboard. Workshop manuals generally show parts diagrams for the engine, clutch, brakes, suspension, and steering. You have to figure it out by feel, more than anything. Good luck. Before doing anything, you should make sure the noise is coming from there, because as you describe it, it could also be the suspension.
