I don't know what has help
14 years 4 months before - 14 years 4 months before #25008 by manual-mecanica
I DON'T KNOW WHAT'S WRONG WITH IT, HELP! Posted by manual-mecanica
Hi everyone, I have a 1985 Renault 18 GTX, but it has a problem. I start it and wait 10 or 15 minutes for it to warm up, and then when I let off the gas to shift gears, it stalls.
What could it be? It also happens when I brake at traffic lights; basically, I can't let off the gas for long because it stalls.
The car is a 2-liter gasoline engine.
Latest edition: 14 years 4 months before by .
14 years 4 months before #25009 by manual-mecanica
Manual-mechanics ' response on the topic Re: I DON'T KNOW WHAT'S WRONG, HELP
Hi,
you can check that the fuel filter isn't clogged, or give it a little more fuel for idling; it's a small screw on the carburetor (use a small flathead screwdriver).
14 years 4 months before #25045 by manual-mecanica
It's carbureted, so you'll have to check if it has an electronic choke, which controls the idle. You can leave it revving a little higher to prevent stalling, but I recommend visually inspecting the vacuum hoses going to the carburetor. If they're okay, service the carburetor. If it still doesn't work, check the vehicle's electrical system. Do you have an electric or mechanical fuel pump?
