Codes
14 years 4 months before #25017 by manual-mecanica
Manual-mechanics response on the topic Re: Codes
This tank doesn't retain gasoline vapors so they can be fed into the engine and burned. But when it gets clogged and the purge solenoid valve activates, instead of sending vapors to the engine, it sends a certain amount of liquid fuel, causing the engine to flood (due to the excess fuel). This is why you're getting a "too rich mixture" and oxygen sensor code
14 years 4 months before #25018 by manual-mecanica
Okay, thanks. I'll take it to the shop on Monday and let you know.
14 years 4 months before #25046 by manual-mecanica
Try testing the car with the fuel filler cap off to relieve back pressure and see how it behaves.
14 years 4 months before #25055 by manual-mecanica
Ok thanks I do it and then I tell you
