PEUGEOT 306 spark problem
14 years 4 months before #25075 by manual-mecanica
Manual-mechanics' response on the topic Re: problem with the spark in a Peugeot 306
Generally, when these types of coils have 4 lines, they have the igniter (power transistor) built in and carry the ignition voltage, ground, and two IGT signals for firing the coils.
14 years 4 months before #25079 by manual-mecanica
: Laugh: Thanks to everyone for your input; it's been a great learning experience. Problem solved: the flywheel where the sensor is located was cleaned, and the sensor itself was replaced along with the coil (which was mandatory). The engine is now running perfectly. Thank you all so much for your help.
