PEUGEOT 306 spark problem
13 years 11 months before #24971 by manual-mecanica
Peugeot 306 spark problem published by Manual-Mecanica
Hello, I have a problem with the Peugeot 306 in one of the four outputs does not throw spark that makes the spark plug work, change the coil, cables and spark plugs, thinking that I do that but it gives me the same problem someone can advise me what to do what to do what would thank you very much for the apprentice. I leave the image of the four -pin coil type.
13 years 11 months before #24974 by manual-mecanica
Manual-Mecanica Response on the Re: Problem with the Peugeot 306 spark
If that is exactly your coil it is impossible for a spark plug not to throw spark unless the coil is bad, because these types of coils work with waste spark, the same coil mandates spark to 2 cylinders that are paired that the pistons rise at the same time but in different race either of compression or escape. I mean that spark jumps in the 2 spark plugs at the same time. If you do not think check it, if your ignition order is 1342 the output of cylinder 1 and 4 throw spark at the same time and if you bring the 2 cables to an inch you will see the spark jump with each other, the same can be done with that of the 2 and 3 cannot jump only to 1 side if the coil is good if it does not throw spark or it is very weakened the coil does not work.
13 years 11 months before #24995 by manual-mecanica
It is true that coil ramp is the one in charge of both cylinders, testing with another coil to see what happens
13 years 11 months before #25061 by manual-mecanica
Hello, the cable that connects the coil with how many volts do you work? I have notice that it brings two blue cables one blacco and one black
13 years 11 months before #25064 by manual-mecanica
Hello friend, as the classmates almost certain the fault is in the coil, try another one that you know is fine, greetings. :)
