PEUGEOT 306 spark problem
14 years 4 months before #24971 by manual-mecanica
Peugeot 306 spark problem. Posted by manual-mecanica
Hello, I have a problem with my Peugeot 306. One of the four ignition coils isn't sparking, which means the spark plug isn't working. I've replaced the coil, wires, and spark plugs, thinking that was the issue, but I'm still having the same problem. Can anyone advise me on what to do? I would greatly appreciate any help. I've attached a picture of the four-pin coil type.
14 years 4 months before #24974 by manual-mecanica
Manual-mechanics' response on the topic Re: problem with the spark in a Peugeot 306
If that's exactly your coil, it's impossible for a spark plug not to fire unless the coil is faulty. This is because these types of coils work with waste sparks. The same coil sends a spark to two paired cylinders, meaning the pistons rise at the same time but on different strokes, either compression or exhaust. So, the spark jumps at both spark plugs simultaneously. If you don't believe it, check it. If your firing order is 1342, the outputs of cylinders 1 and 4 will fire at the same time. If you bring the two wires within an inch, you'll see the spark jump between them. You can do the same with cylinders 2 and 3. The spark can't jump to only one side if the coil is good. If it doesn't fire or the spark is very weak, the coil is faulty.
14 years 4 months before #24995 by manual-mecanica
That's right, that coil pack is responsible for both cylinders. Try another coil pack and see what happens
14 years 4 months before #25061 by manual-mecanica
Hi, what voltage does the cable that connects to the coil operate at? I've noticed it has two blue wires, one white wire, and one black wire
14 years 4 months before #25064 by manual-mecanica
Hi friend, as the others have said, the problem is almost certainly with the coil. Try another one that you know is working. Regards. :)
