Signal sensor and Nissan Xtrail identical tree
14 years 1 month before #26312 by manual-mecanica
Manual-Mecanica Answer on the Re: Signal Sensor and Nissan Xtrail Identic
They could help me, I can't find where the CKP Sensor
14 years 1 month before #26320 by manual-mecanica
The a sensor is located on the right side of the engine, this is seen straight ahead, and the other is located on the back of the engine down, the camshaft sensor is on the right side and has a white mark, it has a higher number than the crankshaft position
14 years 1 month before #26326 by manual-mecanica
Thanks then it goes on the side of the escape, I suppose, now the camshaft if I already found it and it is behind the cylinder head
14 years 1 month before #26368 by manual-mecanica
It is below the starter, logically on the block
