Signal sensor and Nissan Xtrail identical tree
14 years 2 months before #24909 by manual-mecanica
Signal Sensor and Nissan Xtrail identical tree published by Manual-Mecanica
Again I with my Nissan Xtrail 2003 car, yesterday the check Engine was given to me and lead it to scan and turn it off, it turned The car did not develop with the thorough accelerator, it was not over 2500 RMP, it was heavy and super slow to about 20 or 10 km per hour, the light of the check Engine was turned on, I put the sensors to its original state, without having done anything there was when I turned on again there was no longer the focus of check Engine lit and the self -development new. Today for the morning I started well, Andube about 20 km and stacked it in my house for about 20 minutes, I turned it out, andube about 4km and turned off subjectly, the car appears and start it again without any problem and no alarms on on the board. It will be this problem of any of the engine sensors or I will have an electrical problem and if perhaps I do it. Just in case they bought the sensors and in the concessionaire they told me that they are the same and that there is no difference which is above or which below, but check and the codes are A29-660 AJ5 and bring a white mark on its hous WHITE AND HAVE THE NU, HIGHER ERATION?
Thank you very much friends.
14 years 2 months before #24938 by manual-mecanica
Manual-Mecanica Answer on the Re: Signal Sensor and Nissan Xtrail Identic
Curse the two gives you the same function and they work just as preference changes both of you with that, the problem is removed that you do not have false contact in any.
14 years 2 months before #24958 by manual-mecanica
Friend I gave the time with an xtrail in an ocation looking and re -loungeing the fault is well and did not accelerate, the parava closed the contact I taught it and all biem again, in one of those that repair combines the two sensors you mention and all well, in another Change and ninugun problem until today 3 years have passed. Try luck
14 years 2 months before #24987 by manual-mecanica
My friend, today I went out of the vehicle, I should upload it and turned on the check Engine, after walking about 30 minutes, as I already had the sensors bought because I reported the scanner two days before, I went to change them because I got scared, it turns out that it was turned off as I was in a dense traffic. Off, nothing was turned on for a second after returning the key to off and tried to turn it on and accelerated with bombs, well here the story, already in the workshop they passed the scanner and the codisgos of the position sensor of the sigenal identical to what a day ago were found but adding the codiod of the accelerator sensor, they erased the codes and proceeded to change the sensors of the arb Follow, it has not marked any error, the car develops, but I do not know if it is my imagination but I feel something slow until the development reaches. My question is that symptoms you had when I spend about the accelerator sensor.
Thank you
14 years 2 months before #25002 by manual-mecanica
Look with the theme of the accelerator, the car was well marching everything rich and perfect, and at some point it began to look like it sucks and accelerated no matter how much you gave the pedal, then you turned it off and turned it on and all normal again, and so it took it but in summary it starts to stay as it does not accelerate anymore and empies down to lower the speed you turn off and all you turn on and all well.
