failure
14 years 4 months before #24861 by manual-mecanica
Failure published by Manual-Mecanica
I have a problem with a 2001 Chevrolet Astra with a 2.0 8v engine. When I accelerate hard, like when I'm trying to get it moving, it hesitates and backfires through the air filter. I've already replaced several sensors and actuators thinking that was the problem, but it keeps doing the same thing. The only other thing I've noticed after everything I've changed is that the spark plugs aren't burning evenly; one side burns well, and the other side comes out black. If anyone has experienced something similar, I would appreciate any help in finding the problem
14 years 4 months before #24862 by manual-mecanica
Manual-mechanics' response on the topic Re: failure
Have they not distributed it yet?
14 years 4 months before #24877 by manual-mecanica
That's right, first check the timing. If it's running well and backfiring through the intake, which is what you're saying, the problem is electrical. Check the wires, coil, and spark plugs, as well as the condition of the injectors.
14 years 4 months before #24885 by manual-mecanica
What fault codes are you getting? You need to scan it. Check the MAF sensor
14 years 4 months before #24886 by manual-mecanica
You need to check the ignition and fuel pressure. You might have low fuel pressure.
