distribution strap
17 years 9 months before - 17 years 9 months before #2474 by manual-mecanica
distribution strap published by manual-mecanica
Hello: it is my first message and I wanted to greet them all and thank that a page like that exists, so I leave this doubt that I have, it is a VW Polo Fox, of the 93 gasoline, some expert here the same thing knows something, well if you see the photos you will see that the wheel toothed from the bottom of the distribution strap is a bit inclined to one side, when the engine turns, everything goes well. That it does not turn completely straight but rotates ellipically, with the engine running it seems that it is going to come out, when I stop it, I can with my hand straight, as if it were loose, what APSA is that I do not see any twist twist Apra Apra tightening-Soltar-Chamber this piece, someone knows what it is, if it is serious if it is worth fixing it in a 16-year-old car.
IMG114.IMAGESHACK.US/IMG114/693/005HO1.JPG
IMG403.IMAGESHACK.US/IMG403/9994/006UU2.JPG
17 years 9 months before #2475 by manual-mecanica
Manual-Mecanica Response on the Re: distribution strap
Hello. It is also the first time I write, and I have seen your consultation, and the photos.
That is the water pump, and if the rest of the car is more or less well, I think it is worth fixing it, because for the price of rapore you will not buy a car.
My advice is that you repair it as soon as possible, since if the pulley will be completely broken, it will cause consistent damage to the engine.
All the best.
17 years 9 months before - 17 years 9 months before #2480 by manual-mecanica
Hello friend: The truth is that I do not know the engine you are talking about, but because of the indications you aim, it could be the Damper pulley.
This pulley as natural is metal, but its interior is an elastic material that with use, usually breaks. If it is the Damper, I suggest that you repair it quickly because its break would leave the engine unusable.
This pulley when deteriorates a lot of noise, is placed at the exit of the crankshaft and the repair would not have to overcome (in an official service) the € 150.
Zulu greeting
17 years 9 months before #2481 by manual-mecanica
Hi Zulu.
If you look at the photograph, the toothed pulley that is smaller is the water pump, which in these volswagen engines usually break the bearing and take a lot of slack.
The noise is something similar to that of a broken Damper, but based on the photograph I would say that it is the pump.
All the best.
Barriquelo
17 years 9 months before #2497 by manual-mecanica
That is the water pump that is completely destroy !! It is better to change it as soon as possible, what I miss is that I do not throw water to jets.
Greetings and it is very good that there are so many people giving opinion.
